Reply
R9000 Fw dropping Lan connection
bbaraniec
Luminary
@ChristineT @DarrenM with the latest RC firmware, the one I got from you and then one @ChibiKev provided router is dropping connections on ethernet ports. The ports hangs and the only way to fix it is to restart router. That was never happening before.
Best regards
Bartek
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: R9000 Fw dropping Lan connection
Hello bbaraniec
Are you able to send me some router logs of this so I am able to get them to the engineers.
To do this go to 192.168.1.1/debug.htm in your web browser login then click start capture let it run for a bit until you see some disconnect then save the capture and send the file to me.
Thanks
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 243 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
