Reply
R9000 Router Will the Orbi RBS40V work?
rfdnga
Hello I have a R9000 Router but I have some areas that I"m not getting the speed I'd like.
I saw the Orbi RBS40V that appears to be on sale now.   I was wanting to know will it properly work with the R9000 Router? & will it work on the RBS40V
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 5
DarrenM
Sr. NETGEAR Moderator
Re: R9000 Router Will the Orbi RBS40V work?
No, the orbi satellites will only work with an orbi router. You will want to look into our Mesh extenders that would work with your R9000.
DarrenM
Message 2 of 5
Guru
Yes it will work. Disregard what @DarrenM said.  The RBS40V has mesh extender mode that you can use.
https://kb.netgear.com/000061427/How-do-I-setup-my-Orbi-Voice-RBS40V-in-Extender-Mode
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 3 of 5
rfdnga
Ok thank you one last question will it be in simplex then or duplex ?
or is there a different netgear product that would be best ?  and if so why?
Message 4 of 5
Guru
Simplex or duplex? Not sure what you're referring to with that.
the RBS40V will act as a tri-band mesh extender. It dedicates one of its 5ghz bands to communication with the router.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 189 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
