Reply
R9000 new firmware V1.0.2.30
Retired_Member
Not applicable
Hi my x10 updated the firmware to V1.0.2.30 two days ago, but theres no official release post about it, any chance of a release sticky is posted so we all know.
Regards
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 44
Retired_Member
Not applicable
Re: R9000 new firmware V1.0.2.30
New Features and Enhancements:
  • Supports JP SKU.
  • Supports NAS devices for plex media server application.
  • Supports whole drive backup for Amazon cloud backup.
  • Supports link aggregation static LAG mode
Bug Fixes:
  • Fixes security vulnerability issues.
  • Fixes iOS captive portal issue.
To Install
Note: To avoid wireless disconnect issue during the firmware download process, NETGEAR recommends that firmware upgrade be performed on a computer with wired connection.
  1. Write down all the settings which you changed from the default values, since you may need to re-enter them manually.
  2. Using the Download Link below, download and extract the new firmware to a convenient place such as your desktop. The filename after extracting is R9000-V1.0.2.30.img
    Download Link: http://www.downloads.netgear.com/files/GDC/R9000/R9000-V1.0.2.30.zip
  3. Log in to the router using a Web browser. The URL is http://www.routerlogin.net.
  4. Click ADVANCED tab > Administration > Firmware Upgrade.
  5. Click Browse and find the file you just downloaded.
  6. Click Upload. Do not interrupt the upgrade while the router does this step.
Important Note:
  1. The upgrade process is completed when the on screen progress bar completes.
  2. If the upgrade progress bar on web GUI doesn’t display correctly during firmware upgrade, you can still check the status using Power LED. After firmware upgrade is done and boots up the system, it changes to steady amber color.
    Please DO NOT power off or reboot the device during firmware upgrade, otherwise, it  may result to a corrupt firmware and cause the device not to work.
  3. Please do "reset-to-factory default" after the firmware upgrade.
Message 2 of 44
Guru
Any QoS features seen in this version of FW?
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.18.1/RBK50 v2.7.2.104(WW)
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 3 of 44
Retired_Member
Not applicable
The QoS does not work, I set my PC to The highest value, apply, and it goes back to low, worked OK with the last Beta.
Regards
Message 4 of 44
Guru
I would do a complete factory reset on the router and then set up from scratch and see if the QOS settings work. Be sure to clear out all browser caches after doing the factory reset and close then re-open the browser.
Message 5 of 44
Retired_Member
Not applicable
A complete reset has removed the options on setting QoS on individual devices. So there are no options to set QoS apart from the WMM on the 2.4 and 5ghz wifi.
Regards
Message 6 of 44
Guru
Something you should PM Elaine about and let them know. I guess go back and use the beta in mean time.
Message 7 of 44
jeremypsl
Tutor
Re : R9000 new firmware V1.0.2.30
Me too, no QOS option.
Message 8 of 44
TonyPHX
Guide
Yes, this 1.0.2.30 has no QOS options that were "revealed" to us in the beta firmware.  In some ways, this is a "rollback" from the beta.  Clearly, QOS not ready for primetime on the R9000 if Netgear did not put it in the finished firmware product.
I am now wondering when (if ever) we will see QOS options in the R9000 feature set.
Message 9 of 44
Loudog2
Apprentice
How is the QOS feature not enabled on a $500 router?
Message 10 of 44
TonyPHX
Guide
Exactly. i have been working on faith here that it is arriving soon.
Message 11 of 44
Retired_Member
Not applicable
I went back to the beta V1.0.2.18 performance is better now for ethernet connections, hopefully some one at Netgear will release a better version, I havent had this that long so it could be sent back. Was expecting a lot more for having the so called flagship off Netgear, the fastest router ever released, all smoke and mirrors so far.
Regards
Message 12 of 44
TonyPHX
Guide
Well, I am hoping that it will get better with some attention to the firmware.  Elaine has been active in the forums, and I would hope that Netgear takes pride in their premium products for consumers.  I am sure they understand the sales challenges they would face if they do not.
Message 13 of 44
Redtulips7
Apprentice
Oh Lord, NG did it again, NG has released new Firmware after very long time!!! But sadly as usual it don't work, DOA
Nighthawk AX12[RAX120]
Nighthawk X10[R9000]
Message 14 of 44
Redtulips7
Apprentice
Message 15 of 44
Retired_Member
Not applicable
Another problem , which is a feature now removed, but it is advertised:
"MU-MIMO supports simultaneous streaming, while 160 MHz doubles WiFi speeds to mobile devices."
But "Enable HT160"  cannot be enabled under "wifi settings" in "advanced setings"
Anyone else??
Regards
Message 16 of 44
Fryingmonkey
Can no longer see any of my wireless attached devices, only wired. Great update. >.<
Message 17 of 44
Lexist2112
Luminary
Updated to this latest FW 1.0.2.30. Knowing well, that QoS was not working. As other have mentioned Basic>Home>Attatched Devices box, says 19 Devices, however when you click on the box, it only shows 3devices connected, 2 wireless and 1 wired.
Netgear you need to fix:
1) QoS
2) Attached devices
Message 18 of 44
Guru
Do you do the factory reset and set up from scratch to be sure SIR?
1) QoS
2) Attached devices
Message 19 of 44
Redtulips7
Apprentice
Oh yes Netgear will fix it by 2018 then by that time new R10000 will be release!!!
Message 20 of 44
Guru
Has anyone tried Merlins 3rd party FW or OpenRouters FW? Just something to suggest trying while everyone is waiting on NG to implement QoS. Smiley Frustrated
Message 21 of 44
Guru
Couple of issues using 3rd party FW:
Currently known issue:
-2G and 5G leds are not operational since they cannot be controlled through gpio. Current opensource wireless driver has no support to control these leds.
-60G interface info is currently not correctly display in status pages and due to missing 60G client, 60G operation is untested
Message 22 of 44
TonyPHX
Guide
Incidentally,
Some really new odd behavior with this router after the 1.0.2.30 update.  After the update, try using the VPN and then getting to any internal web server on your network.
Message 23 of 44
Tmoore1710
Tutor
What did everyone expect?? The r8500 was the so called flagship too and it still doesn't work. My first one I bought is over in a drawer bit the bullet after 4 months but missed the warranty from my job being away. I'm hard headed so what do I do yep go buy another & after a whole whopping week of hell its now stuck in the boot loop. Shame on me me once....Shame on me twice....Netgear please fix what you have out instead of paying hired hands to work on something new.
Message 24 of 44
Redtulips7
Apprentice
NG needs replace their Engineers with others whom can deliver or produce not just release nonsense FW!!!
Message 25 of 44
Top Contributors
Discussion stats
  • 43 replies
  • 5189 views
  • 7 kudos
  • 15 in conversation
Announcements
