Reply
R9000: no Internet with VLAN enabled
PauLita
Luminary
Nighthawk X10 R9000 immediately loses internet with VLAN enabled:
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 21
ElaineM
NETGEAR Employee Retired
Re: R9000: no Internet with VLAN enabled
Welcome to the community, @PauLita
Kindly upgrade the firmware of your router and factory reset it afterwards.
Once done, reconfigure the router to get back the connection and configure your VLAN settings.
ElaineM
NETGEAR Community Team
Message 2 of 21
PauLita
Luminary
I do repeat:
1. VLAN disabled - no problems with internet.
2. VLAN enabled - no internet.
3. VLAN disabled - no problems with internet.
4. VLAN enabled - no internet.
5. VLAN disabled - no problems with internet.
6. VLAN enabled - no internet.
Shall I repeat some more times?
Message 3 of 21
PauLita
Luminary
Let us do more experiments:
1.	Factory reset
a)	No problems with Internet (port1)
b)	Router (192.168.1.1) accessible via port 1
2.	Enable VLAN “By VLAN tag group”
Name=Internet, VLAN ID=10, priority=0, Wired ports=all
a)	No Internet (port 1)
3.	Disable VLAN
a)	Internet returns (port1)
a)	Router (192.168.1.1) accessible via port 1
4.	Enable VLAN “By VLAN tag group” and change ID from 10 to 1:
Name=Internet, VLAN ID=1, priority=0, Wired ports=all
a)	Internet disappears (port 1)
b)	No way anymore to connect to Router (192.168.1.1 or www.routerlogin.net) via port 1
5.	Factory reset
6.	Enable VLAN “By VLAN tag group”, add VLAN ID=1 on port=5:
Name=Internet, VLAN ID=10, priority=0, Wired ports=1,2,3,4,6
Name=1,VLAN ID=1,priority=1,Wired port=5
a)	No Internet (port 1), no Internet (pot 5)
b)	Router (192.168.1.1) accessible via port 1, not accessible via port 5
7.	Enable VLAN “By VLAN tag group”, add VLAN ID=6 on port=6:
Name=iptv,VLAN ID=6,priority=6,Wired port=6
a)	No Internet (ports 1,5,6)
b)	Router (192.168.1.1) accessible via port 1, Router NOT acessible via ports 5,6
c)	iptv of Telia is on port 6!!!
8.	Disable VLAN
a)	Internet returns (ports 1,2,3,4,5,6)
b)	Router (192.168.1.1) accsessible via ports 1,2,3,4,5,6
Message 4 of 21
ElaineM
Do you have the latest firmware installed?
ElaineM
Message 5 of 21
PauLita
Luminary
Yes, I do - Version 1.0.2.40.
Message 6 of 21
ElaineM
Kindly register the router so that we can create a case for you.
ElaineM
Message 7 of 21
PauLita
Luminary
Could not register as I purchased R9000 on AMAZON and previous owner did not unregistered it - serial number 4N016C5800***.
Message 8 of 21
ElaineM
Do you have a proof of purchase?
Can you try to hard reset the unit once more?
1. With the unit powered on, press and hold the reset button on the back of unit for 30seconds.
2. Without releasing the reset button, unplug the unit and hold reset for another 30 seconds.
3. Power on the unit while STILL pushing the reset button and count for another 30 seconds before letting it go.
ElaineM
Message 9 of 21
PauLita
Luminary
due to time difference I will try hard reset later....
Message 10 of 21
ElaineM
Kindly provide feedback once you have tried the reset.
By the way, the imaged you have attached is disapproved for your security.
ElaineM
Message 11 of 21
PauLita
Luminary
Tried 30+30+30 Hard Reset for several times. I DOES NOT work as expected:
1. 30+30+30
a) Router's power LED blinks repeatedly
b) ping 192.168.1.1 OK
c) www.routerlogin.net -> "Server not found"
d) 192.168.1.1 in browser -> "LuCI - Lua Configuration Interface" on black screen for few seconds -> "can't reach this page"
e) wait for 15..30 min. No changes.
d) repower router
e) router returns to work WITHOUT erasing previous saved configuration!
P.S. was the image of an invoice a proof of purchase or shall I send You a copy via PM?
Message 12 of 21
PauLita
Luminary
Shall I remind, that my problem with R9000 is exactly as this (unsolved) problem: Nighthawk-X6-R8000-and-VLAN-IPTV
Message 13 of 21
PauLita
Luminary
And this one:
Message 14 of 21
PauLita
Luminary
And this one:
Message 15 of 21
steverib
So PauLita, I assume the no Internet with VLAN was never resolved?
Message 16 of 21
PauLita
Luminary
Yes, the problem is not resolved! Almost two weeks had passed from the last Netgear attempt, and no news from then...
Message 17 of 21
steverib
That is too bad, I have the newest R7000P which has been great in all other respects.  From the other sources i've been able to read is seems that turning on any VLAN tagging essentially disconnects the Internet Port.  I don't believe it is a hardware issue as alternative firmware such as Open-WRT or Tomato supposedly will do it with Netgear hardware.
The "solution" of purchasing a cheap switch just to do tagging on the WAN side is ridiculous.
Message 18 of 21
PauLita
Luminary
As I mentioned already in other thread, I was given a debug version of FW witch allowed to specify main (internet) VLAN number equal to 0, and additional VLAN #6 for my iptv. This HAD solved the problem - internet AND iptv has neen working together! Sorry, but this ability (VLAN #0) is missing in the main FW.
Message 19 of 21
volcano2K
Edit the vlan(internet) : 0 and 0 save..
Message 20 of 21
PauLita
Luminary
OK, I returned to FW version V1.0.2.40, and set Internet VLAN ID to 0. Internet AND iptv are working.
One bug left: there is no way to assign 10Gb SFP port to any VLAN (though it duplicates port #1).
Indeed, I badly need additional feature: it is necessary to be able to assign different VLANs to the same LAN port – for example my iptv provider translates also additional information about current channel viewed – show name, next show info, duration etc. Also current provider’s router  is able to translate to the same LAN port iptv+info, AND internet, AND NAS.
Message 21 of 21
Top Contributors
Discussion stats
  • 20 replies
  • 9207 views
  • 0 kudos
  • 4 in conversation
Announcements
