× Some paid Circle Parental controls customers may be showing free options only. Router firmware correcting this issue will be available ASAP. Visit Status.NETGEAR.com for updates.
Discussion stats
  • 2 replies
  • 178 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
R9000 not working blinking some lights
Hi, this morning my router stoped working an some lights are blinking constantly.
The lights that are blinking white are power-internet-usb1-usb2-and the two last keys.
Blinking Amber and softer all the Ethernet ports.
I made some research and triyed a 30-30-30 reset but nothing happened.
Please some help.
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 3
Highlighted
Master
Re: R9000 not working blinking some lights
30-30-30 reset has no effect on ARM-based routers. It's a relic of the past and many people still think it works, which it doesn't.
Your router is most likely bricked (did you have Firmware Auto-Update turned on? if so, DO NOT DO THAT AND TURN IT OFF). For debricking, try the TFTP steps at https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
Routing: NETGEAR R7800 - Voxel Firmware 1.0.2.77SF & kamoj addon
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400
Message 2 of 3
Highlighted
Thanks microchip8,
But unfortunately it didn't work.
I also tried with the cmd console of windows but the tftp cmd doesn't exist.
Is there any other way to try?
Thanks!
Message 3 of 3
