- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R9000 - problem with VPN IPSec
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
after the firmware upgrade (to version 1.0.5.28) I observe problem with connection through VPN IPSec (Cisco AnyConnect).
After several hours of work, I cannot connect via VPN. A reset of the router helps and I can log in again via VPN.
Previously, the problem did not occur with an earlier firmware version.
Please help me to solve the problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R9000 - problem with VPN IPSec
here's the order i'd try.
1. factory reset the router and reinstall. Sometimes old settings cause issues.
2. reinstall the firmware. maybe something didn't install correct and is corrupt.
3. downgrade the firmware. maybe it did introduce a bug.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you writing seriously?!
Factory reset and setting up all settings and computers from scratch is a half day job!
This is not a solution to my problem 😞
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Ra-Dzik wrote:Are you writing seriously?!----didn't you post on here? So I'm writing to respond.
Factory reset and setting up all settings and computers from scratch is a half day job!----then maybe simplifying your setup or how you're doing it is in order if its taking you a half a day to install a router.
This is not a solution to my problem 😞-----Ok, do you see a giant "fix it" button on it? No? I dont' either. There are no simple "click this" and its fixed buttons.
