Orbi WiFi 7 RBE973
Reply
R9000 unable to set wireless schedule
user12a
Star
I am unable to set the wireless on/off schedule in the setup.  The setup boxes to turn off are all grey-outed under Advanced Wireless Settings.  I have tried it on the latest firmware 1.0.5.8 and 1.0.5.14b.  How do I enable the schedule.
This R9000 model has been out for 3 yrs and I am surprised if this basic feature is not working after all this time.  I just got this model mainly to use the Plex feature.  Someone please help.
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 5
Accepted Solutions
user12a
Star
Re: R9000 unable to set wireless schedule
I tried to preset all my router settings before going live.  Apparently some setting cannot be set until you are connected to the internet,  kinda rediculous.  This is one of them.  I figured out the next day.
Message 3 of 5
All Replies
DarrenM
Sr. NETGEAR Moderator
Have you tried to use another web browser when changing the setting?
DarrenM
Message 2 of 5
user12a
Star
Message 3 of 5
antinode
Guru
> [...] Apparently some setting cannot be set until you are connected to
> the internet, kinda rediculous. [...]
   Perhaps not ridiculous.  Without an Internet connection, the router
probably can't use NTP to set its date+time.  Not knowing the time might
be a reasonable excuse for not accepting schedule data (which can't work
properly).
   Greater familiarity with "Chicago" song lyrics might have helped.
Apparently, the R9000 firmware really cares.
Message 4 of 5
user12a
Star
The on off schedule is independent of the actual time.  If you have used it, you would know.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1108 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
