Reply
R9000 v1.0.4.26 firmware - Instructions - "Important Note #3" - Reset??
SEHome
Follower
Firmware v 1.0.4.26, Instructions, "Important Note #3" (red text).  Instructs user to "reset to factory default" after posting this firmware.  Is that required?  What's the impact if I don't take that step?
Link to instructions: https://kb.netgear.com/000060523/R9000-Firmware-Version-1-0-4-26
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 2
Re: R9000 v1.0.4.26 firmware - Instructions - "Important Note #3" - Reset??
A factory reset is not always needed. If you do not do it, you may experience post-flash problems. You may also miss out on any new features that the firmware enables.
The usual strategy is to leave well alone, and to reset only if you have problems.
It can help to take screen grabs of the settings should you need to reconfigure the device. Reloading saved settings is not recommended.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 334 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
