Reply
R9000
Memosalah83
R9000
After upgrading to 1.0.4.12 image wifi ssids configured on same router becomes unstable, disconnect and stuck while i can connect to tplink APs linked by cable to router without any issues.
I have reset it to default factory settings then re configured it manually but still having same problem help plz
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 8
Memosalah83
Re: R9000 firmware
R u sure is it working on r9000??
Message 2 of 8
Memosalah83
Re: R9000 firmware
What is the difference please between R9000-V1.0.4.13HF & HF-HW ??
Message 3 of 8
Memosalah83
Re: R9000 firmware
Installed voxel 1.0.4.13hf do i have to reset to factory settings?? And reconfigure manually or no need ??
Message 4 of 8
Memosalah83
Re: R9000 firmware
Thnx gentleman i will test it now and revert back to u thnx a lot
Message 5 of 8
Memosalah83
Re: R9000 firmware
Same issue i think i have to reset it
Message 6 of 8
Memosalah83
Re: R9000 firmware
Yes sure thank u
Message 7 of 8
GianniD
Re: R9000
fw ver: V1.0.4.12
Problem exists with Join/Connect action when adding devices to the main private wireless networks, 2.4G and 5G.  This problem is not experienced with wireless Guest networks, nor Ethernet.
Some devices report only "connection failure" or "failure".  IOS devices report "Incorrect password" for "<SSID>".
Knowing a little something about code, string manipulation, led me to try preceding the correct password string with a space character (when entering the log-on/connection info on the device I was attempting to add to the network).  Suddenly connection was successful!
I was able to duplicate/repeat this behavior several times.
Therefore I conclude that the first character of the password string is being dropped somewhere in code error.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 633 views
  • 0 kudos
  • 2 in conversation
Announcements
