× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX200 AirPrint Intermittent
jimmcc
Follower
Config:  Nighthawk RAX200 with latest Firmware. ISP Router (192.168.x.x) with one connection to Nighthawk (10.0.0.x).  Nighthawk only has a couple of devices hardwired, all others are Wifi. ISP is 500/800 up/down on average.
I have a Canon MFC743cdw (latest firmware) on static IP / wifi off Nighthawk (10.0.0.74).  If I reboot my router, I can discover my Canon (Printer / Scanner) via AirPrint from Mac(s) and iPhones, great.  but after some period of time, sometimes hours, sometimes 24-48 hours, the AirPrint connectivity is no longer available.  I can connect via LPD to the printer but that doesn't help iPhone connectivity.  happens with two different printers and three different Macs.  Seems to be consistently working if I reboot the Nighthawk...  Any suggestions?
Jim
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 2
Guru
Re: RAX200 AirPrint Intermittent
Might help to fix your double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
Cascading routers (with both in router mode) can cause issues.
Options?
1. Put the isp modem/router in passthrough/modem only mode.
2. Put the netgears IP address into the ISP router's dmz
3. put the netgear in access point mode.
Message 2 of 2
Discussion stats
  • 1 reply
  • 575 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
