× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX80 keeps disconnecting
user1234234
Follower
My RAX80 keeps disconnecting from devices, wifi and wired. But Remote Management still works through the Nighthawk app via mobile data connection.  I have the lastest firmware update. Any ideas? This has been the most frustrating router I have ever owned and I have gotten 0 support from netgear this far. Really frustrating trying to find a solution for this.
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 2
Guru
Re: RAX80 keeps disconnecting
Which version of the firmware are you on?
What modem are you conencted to?
Have you tried a simple factory reset and manual reinstall? The RAX devices are the newest of the new and got many firmware changes during updates. this has caused them to respond favorably to resets.
Message 2 of 2
Discussion stats
  • 1 reply
  • 621 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
