Reply
RBK53 bloque sur "veuillez patienter" interface web box orange fibre
xavierprof2
Follower
Bonjour
Je viens de passer à le Fibre chez Orange avec une livebox 5.
J'arrive à me connecter à mon Netgear Orbi RBk53 depuis un navigateur WEB (Safari, Mozilla, Edge...), mais l'interface WEB ne charge pas. Elle reste bloqué sur "veuillez patienter quelques instants...".
Tout fonctionne bien depuis l'application iPhone, mais pas depuis un PC Windows 10 ou un MAC OSX. Seul les commande sur la gauche de la page apparaissent. Le centre de la page WEB reste vide.
Merci pour l'aide.
Message 1 of 3
Guru
Re: RBK53 bloque sur "veuillez patienter" interface web box orange fibre
en anglais s'il vous plaît
Netgear has set up a community forum specifically for the Orbi AC (WiFi 5) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Thank you.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.3.5(Router mode/LAG Disabled) & EX7700x2
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, and WNHDE111
Message 2 of 3
Guru
Livebox is its own router and has its own routing functions.
It causes a double nat and can sometimes cause issues.
A double nat happens when you cascade more than 1 router.
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-pro-wifi
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-M...
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 72 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
