Orbi WiFi 7 RBE973
Reply
Radius problem
amrashraf
Radius problem
i have netgear model R6850 firmware V1.1.0.78_1.0.1
ihave problem i activated radius server on my netgear everything work perfect but when i dissconnect wifi from my phone and reconnect after hours i cannot connect again
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 5
amrashraf
Re: Radius problem
any one help me please
Message 2 of 5
Guru
Re: Radius problem
Does using a non radius WPA2 configuration work?
Not much radius configurations seen on Home class routers. Something more in tune with small or larger business class wifi systems
Message 3 of 5
amrashraf
Re: Radius problem
you mean this model r6850 dosnot support radius...... i try another access point(ip time) every thing is good idont know what is the problem with netgear!!
Message 4 of 5
Guru
Re: Radius problem
Be sure your using most current version of FW.
Might contact NG support regarding this however that model router is getting to be a bit older and may not be fully supported anymore.
Something to ask NG support about.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 640 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
