- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Range Reduction on Nighthawk R7000 – Part 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, I've had the Nighthawk R7000 for about 1 year now and it has performed with excellence.
Within the past month however I've noticed a very weak wireless signal when moving far away from the router within my apartment. At times I'm unable to connect to the WiFi signal at all whereas before I had no problems…I'm also using a Netgear Extender from which I’m also experiencing the same issues.
The strange part is that only the 2.4 GHZ channel is experiencing these glitches. The 5 GHZ channel seems to get good coverage all over the home whereas before it was limited to a very small distance range. Nevertheless, I want to continue using the 2.4 channel for all wifi computer and mobile devices within the home.
Here are some troubleshooting steps I’ve completed so far but haven’t helped:
- Tried rebooting both devices
- Since I live in an apartment building, with many neighboring wifi connections, I tried switching to other wifi channels that weren’t so busy
I appreciate any assistance.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
"The strange part is that only the 2.4 GHZ channel is experiencing these glitches"
The router has TWO distinct radios, One of them appears to be failing. Try re-installing FW and or factory reset, try switching the antennas around ( one may damaged ) All this should be done with extender turned OFF.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Range Reduction on Nighthawk R7000 – Part 2
switching the antennas did the trick...appreciate!
