Reply
ReadyCloud with R7000 and Attached USB Drive
jsguy16
I have followed the directions to set up ReadyCloud on my R7000 router.  When I login to ReadyCloud, I can see the icon for the R7000, but when I double click on the icon, no folders or files will appear.  I have the same issue when I use the desktop ReadyCloud app.  What should I do?  Thanks
Message 1 of 7
storm1985
Prodigy
Re: ReadyCloud with R7000 and Attached USB Drive
post the screenshot of the ReadyShare tab
Message 2 of 7
JamesGL
Master
Hi jsguys16,
Do you still have the same problem? If yes, you can try:
1. To unplug and replug the USB drive on the router.
2. Unregister and register your ReadyCloud account.
Message 3 of 7
jsguy16
I tried this and it did not work.   My Nighthawk router is connected to the DMZ port on a Comcast modem/router.  That might be the issue?
Message 4 of 7
JamesGL
Master
Hi jsguy16,
Can you set the modem/router to modem only and let the R7000 work as the router?
Message 5 of 7
jsguy16
No, because I am using the Xfinity Security System, so I can not use bridge mode.
Message 6 of 7
JamesGL
Master
Hi jsguys16,
What is the firmware version of your router?
Can you access the drive locally(HTTP,FTP,//readyshare) ?
Please reset the router to factory default and manually reconfigure.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1821 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
