Reply
ReadyNAS 31600 Booting problem; system hangs when booting reaches 99%
AvaneeshBajoria
Follower
We have a Netgear ReadyNAS Model 31600.  This morning the device booted but at 84% it got stuck.  It stayed so for about an hour, thereafter I restarted it manually.  by hard pressing the power button.  After restarting, it progressed till 99% and then again got stuck and stayed so for another hour.
I am not able to access the device over the network through its designated IP.
Any suggestions would be appreciated.
Thanks.
Model: RN31600|ReadyNAS 300 Series 6- Bay (Diskless)
Message 1 of 2
Re: ReadyNAS 31600 Booting problem; system hangs when booting reaches 99%
As the nae says, the RN31600 is a ReadyNAS device. You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
ReadyNAS Network Storage: Official NETGEAR Community
There is not much on common between ReadyNAS and the router covered here.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 48 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
