Oldsports
Mar 11, 2022Aspirant
ReadySHARE storage creates temporary files
I have an R8500 (firmware V1.0.2.128) with a 250GB USB drive (NTFS format) connected to the router via ReadySHARE storage. Access to the files is working great from my Windows 10 computers. The issue I am having is that when I open a file on the drive, a temporary file is being created that does not always go away after I close the file. I have not determined a pattern - it seems to happen whether I open/edit a file or if I just open/view it. Also, it does not happen all of the time - sometimes the temporary file is not there after I access a file.
It is not causing any functionality issues (as far as I can see) but it is annoying. After a while, I go in and delete all of the temporary files that have been created since the last time I did it. I am not running the latest firmware; I experienced wireless stability issues with more recent firmware updates so I am running the firmware that has been most stable for me. If my issue has been addressed in a later firmware issue, I will weigh whether I want to keep living with it or take a chance with messing up my wireless network. Does the drive's format (NTFS) matter? I can change that if necessary.
Any help would be appreciated. Thanks!
Does the same thing happen when you work on files on USB drives connected directly to the PC rather than through ReadySHARE?
This sort of behaviour is usually down to the software that you are using to access files. Some things are better than others at housekeeping.
Then there is the habit of Windows – if that is what you are using – to leave rubbish lying around. It isn't really something that ReadySHARE has much to do with.
- OldsportsAspirant
michaelkenward- Thanks for the reply. No, the behavior only occurs when using ReadySHARE. When I use USB drives directly attached to my PC the temporary files are not left behind. I also have a home server (WHS 2011) that I use very often and no temporary files are left behind. The files are being generated when I use the standard MS Office products (Excel and Word mainly).
One thought - Are temporary files normally hidden? If so, it is possible that I am looking at the hidden view on the ReadySHARE so I see the temporary files? If I look at the hidden view on a USB or on my server, I wonder if I will see temporary files created. Unless you know the answer, I will try this out an report back.
Thanks!
Good thinking.
My experience is that temp files are visible. Local and ReadySHARE USB. But I like to see stuff.
Here at least tmp files go away when I close Office files.
Of course, there are times when a file might not close properly. And that would leave junk lying around.
