Reply
ReadyShare - Admin Password Protection Problem
MaddHatter00000
Using USB drive with pictures and music files, plugged into R7900P router.
When selecting Admin Password Protection for Network Neighborhood, then opening file explorer to open READYSHARE, the expected dialog box opens to enter the password to allow access to the file. Entering the password will not open READYSHARE. The dialog box reopens as if the wrong password is entered.
When Admin Password Protection is used for HTTP or HTTPS or any of the other access options, the entered password correctly allows access to the file.
File explorer will open and see all files within READYSHARE if Admin Password Protection is turned off.
Using ReadyCloud Client 1.19, R7900P router.
Model: ReadySHARE USB Storage Access|Convert USB storage into network storage
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 409 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 6E
