- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyShare Registration Fails - R7000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, I am trying to register my router (R7000) with ReadyShare account but getting this message "Registration failed. Please check your user name and password and try again". I tried changing password and my password doesn’t have special character in it but same issue. Credential works fine on website. I have the latest firmware V1.0.7.10_1.2. Can anyone help please?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have factory reset the router and strated again from the begiinging and it worked. Previously I was restoring old backup file after the router reset. Router now has exactly same configuration but new one. Not from old backup. And readycloud is working fine. Thanks for you support @JamesGL. Really aprriciate it.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyShare Registration Fails - R7000
Hi ArnySaha,
Try using a simple password like "password123" and check if the same error.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi JamesGL, I already tried that few times but same issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi ArnySaha,
Can you try again. Mine works fine when using that password.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks JamesGL. I am using exactly "Password123" but same issue. I was using as simple as "Apple123" before but same issue. Are you using R7000? Not sure if I am doing anything wrong or it is a Netgear ReadyCloud issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi ArnySaha,
Yes I am using an R7000 router. Try to reset the router and check again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi ArnySaha,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks JamesGL. I tried, reboot, reset, changing password. Kind of gave up now. Hopeless service of Netgear ReadyCloud.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi ArnySaha,
Check your inbox.
- Mark as New
- Bookmark
- Subscribe
- Permalink
