Reply
ReadyShare Slow
MeadDogMan
Follower
ReadyShare Slow
I hooked up a WD MyBook to the router's USB 3 port.  When I try to copy files to the device, the write speeds are really slow.  Is this normal?  Any way to improve these speeds?
Thanks.
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 6
JamesGL
Master
Re: ReadyShare Slow
Hi MeadDogMan,
1. What is the speed you are getting?
2. Is the connection wired or wireless? If wireless, check wired connection and compare.
JamesGL
Community Team
Message 2 of 6
mead_dogman
Re: ReadyShare Slow
Hi JamesGL:  I copied a 12.5 gig folder from my Windows 10 PC to the USB 3.0 ReadyShare WD Elements 3 TB drive and averaged about 37 to 40 MB/second.  I copied the same 12.5 gig folder to a Seagate GoFlex Home 2 TB network attached drive and averaged about 30 MB/second.
Would you say the ReadyShare is averaging the correct USB 3.0 speed?
Thanks for your assistance.
MeadDogMan
Message 3 of 6
JamesGL
Master
Re: ReadyShare Slow
Hi mead_dogman,
If you connect the 3TB drive directly to your computer and copy the file, what is the speed?
JamesGL
Community Team
Message 4 of 6
JamesGL
Master
Re: ReadyShare Slow
Hi mead_dogman,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
JamesGL
Community Team
Message 5 of 6
mead_dogman
Re: ReadyShare Slow
I've decided to stick with my current backup plans and abandon the ReadtShare as an option.
Thanks for your asistance.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2873 views
  • 0 kudos
  • 3 in conversation
Announcements
