Reply
ReadyShare can't find USB drive
Jarosz96
I have downloaded "readySHARE Vault" on my stationary computer and set up a backup drive that is connected to the router. I wanted to do it to my laptop aswell but I can't select any backup drives on "readySHARE Vault" there. I have tried reinstall the program with no success.
I can find the USB-storage when I go to "Run" and type "\\Readyshare" on both the computer and laptop.
I can aswell find the USB drive on "Netgear Genie" on my laptop.
I have tried reinstall the program with and withot the USB drive on.
(Update: I have restarted my computer and now I can at least se my drive on the computer C:, but still not the USB drive connected to the router. But when I exit and open "readySHARE Vault" my C: drive is gone again).
Model: R6800|Nighthawk AC1900 Smart WiFi Router
Message 1 of 2
Jarosz96
Re: ReadyShare can't find USB drive
Update: I used the built-in Windows backup software and just selected the USB folder connected to the router. It is backing up now but not through "ReadySHARE Vault" which I prefered to use. The USB folder is visible through my laptop, just not through "ReadySHARE Vault".
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 422 views
  • 0 kudos
  • 1 in conversation
Announcements
