Reply
Readycloud does not show files....using R7000
Burner7999
Follower
I log into Readycloud from my browser and the only thing that shows up is my R7000 router.  I tried right-clicking and selecting browse but still I am unable to see any of my backed up files.  I am able to access everything from my iPhone app which is really puzzling.  I also tried to install the Desktop app but it keeps freezing during the install and won't install properly either (currently running Windows 10).  If anyone knows a work-around would be very helpful.  Thank you.
Message 1 of 11
mlabno
Re: Readycloud does not show files....using R7000
having same problem, can acess from galaxy phone, but cant not access through signing in through web
Message 2 of 11
JamesGL
Master
Hi All,
Do you still have problems with ReadyCloud? If yes, may I know what firmware version you are using?
Message 3 of 11
wfc990
i face the same problem as well, i can browse the file via the local network (\\readyshare), but readycloud fails to detect my drive, it just show my r7000 router and says it is not connect with any devices.
my r7000 firmware should be the lastest verison.
Message 4 of 11
JamesGL
Master
Hi wfc990,
What is the exact firmware version the router is using?
Message 5 of 11
JamesGL
Master
Hi Wfc990,
Please provide us update with your case.
Message 6 of 11
Jayson
My router's FW is 1.0.4.30. I encounter this problem,too.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 7 of 11
JamesGL
Master
Hi Jayson,
Please try this new firmware.
http://kb.netgear.com/app/answers/detail/a_id/30695
Message 8 of 11
Jayson
Hi
Thanks for your information.
I upgraded the FW. But I still encounter this problem.
After I did several tests. I found if i set the read /write security(need admin) , I cannot see the file in Ready cloud.
If I set without security (no password) it works.
P.S. I did not encounter this prblem using readycloud account (not mynetgear account), even I set the security.
Thanks
Message 9 of 11
JamesGL
Master
Hi Jayson,
Reset has been performed after the update, am I correct?
Message 10 of 11
JamesGL
Master
Hi Jayson,
Any updates regarding your case?
Message 11 of 11
Discussion stats
  • 10 replies
  • 2582 views
  • 0 kudos
  • 5 in conversation
Announcements
