- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Readyshare USB stopped working after update to Firmware V1.0.5.70
- Mark as New
- Bookmark
- Subscribe
- Permalink
I updated the Firmware to V1.0.5.70 and my Readyshare USB function stopped working. It has been set up and working fine for several years until this update. I have tried 12 different USB flash drives in both the front and rear port with no luck. Multiple reboots have also made no difference. I have notices the USB plug gets very warm but it may have always done that.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi PetrSvarc,
Reset the router to factory default and manually reconfigure the device. Check if the USB drive is being detected. Check as well if the drive is working if connected to the computer.
JamesGL
Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Readyshare USB stopped working after update to Firmware V1.0.5.70
Hello dwturner,
What's the model number of Netgear product?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello dwturner,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- Mark as New
- Bookmark
- Subscribe
- Permalink
The model of the product is R7000 (AC1900 smart wifi router), I thought I had marked it in the tags.
Thanks
Dave
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi dwturner,
Reset the router to factory default and manually reconfigure the device. Check again the ReadyShare after the reset if it is already working.
JamesGL
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi dwturner,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
JamesGL
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
After update to firmware V1.0.7.2_1.1.93, USB3.0 stoped working with ICYBOX IB -RD3620SU3.
I know that Netgear has the list with approved external disks and boxes, But this box has worked!!! Can you fix it Netgear, please ? Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi PetrSvarc,
JamesGL
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi PetrSvarc,
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
