Reply
Readyshare folder on USB drive doesn't show folders that begin with a PERIOD
silverspyder
I have a external HD that I've been storing all of my saved videos on for a while.  When I received my Nighthawk, I plugged it in to the router for the Plex feature.  After hours of "catalogging" the videos, I noticed MANY were missing.  All of the videos had 1 thing in common, the subfolders they were located in began with a PERIOD.  Example: ".HOME VIDEOS".  You may be aasking why I did this.....it was to make them appear at the top of the list(alphabetical order).  They don't even show up when I mapped the drive on my PC.  I can't access the folder by searching for a file name, then access it, but for some reason, the Nighthawk ignores folders that begin with a PERIOD.  I removed the PERIOD and like magic...it appears in the folder list naturally.  Can this be fixed or do I need to remove the PERIOD from all the folders to make them appear in the folder list and for Plex to find/index them into my library???
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 3
antinode
Guru
Re: Readyshare folder on USB drive doesn't show folders that begin with a PERIOD
> [...] Can this be fixed [...]
   Probably, but perhaps not by you.
> [...] or do I need to remove the PERIOD from all the folders to make
> library???
   A leading dot is used on UNIX(-like) systems to make a file "hidden",
which means that it won't appear in many file listings.  If the
file-sharing software involved here follows that convention, then
changing those names may be your only practical option.
> [...] it was to make them appear at the top of the list(alphabetical
> order).
   Many other characters could do that:
      https://en.wikipedia.org/wiki/ASCII
Of course, some of those might cause problems of their own.  You'd need
to run the experiment, but I'd expect these to be pretty safe:
Message 2 of 3
IrvSp
Master
Interesting, but I have NO PROBLEM seeing folder that start with a period, see screen capture of Windows Explorer looking READYSHARE on the router on the right,
I do have Explorer set to show all folder, System, Hidden, etc.
Suspect you do not have those set. Here is a DIR of the Readyshare drive using the sharename;
C:\>dir \\readyshare\usb_2.0_storage
 Volume in drive \\readyshare\usb_2.0_storage is USB_2.0_Storage
 Volume Serial Number is 6F06-9E72
 Directory of \\readyshare\usb_2.0_storage
03/16/2018  02:25 PM    <DIR>          $RECYCLE.BIN
10/26/2018  10:43 AM    <DIR>          .
01/01/2015  01:00 AM    <DIR>          ..
12/25/2017  12:10 PM    <DIR>          Acronis Backup
11/10/2016  08:23 AM         5,453,003 ATI2016_userguide_en-US.pdf
08/16/2016  05:14 PM        50,449,456 dotNetFx40_Full_x86_x64.exe
05/12/2018  01:39 PM    <DIR>          netgear_downloader
09/13/2018  02:55 PM                48 New Text Document.txt
06/13/2018  07:59 PM    <DIR>          Pictures
05/26/2018  07:28 PM                19 qc
03/05/2012  06:44 PM         1,644,118 SeagateExpansion.ico
01/13/2016  10:00 PM           611,096 seatools-for-windows-en-us.pdf
05/12/2018  11:25 AM    <DIR>          share
05/12/2018  01:37 PM    <DIR>          System Volume Information
01/14/2016  11:47 AM    <DIR>          VProRecovery
               6 File(s)     58,157,740 bytes
               9 Dir(s)  1,208,285,044,736 bytes free
C:\>dir \\readyshare\usb_2.0_storage /a ash
10/09/2018  08:42 PM    <DIR>          .ReadyDLNA
              10 Dir(s)  1,208,285,044,736 bytes free
Note the difference on the 2nd DIR using the Attributes of ASH... the folder IS showing.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1062 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
