Orbi WiFi 7 RBE973
Reply
Readyshare for HP
Granddude
Readyshare for HP
P1606dn
Are some older HP printers not compatible with Readyshare? I can't see my HP P1606dn.
Model: R6120|AC1200 Dual Band WiFi Router
Message 1 of 3
Accepted Solutions
antinode
Guru
Re: Readyshare for HP
> [...] I can't see my HP P1606dn.
   "see"?  Where, exactly, are you looking?  How, exactly, is your
P1606dn connected to anything?
   All I know is what I read in the "LASERJET PROFESSIONAL P1560 and
P1600 Printer series User Guide":
      https://support.hp.com/us-en/product/hp-laserjet-pro-p1606-printer-series/4110408/model/4110409/manu...
      http://h10032.www1.hp.com/ctg/Manual/c01714998
But what I see there is:
      The HP LaserJet Professional P1600 printer series can connect to
      networks through the HP internal networking port.
   If your printer is connected to your LAN using an Ethernet
connection, then I see no use at all for ReadySHARE to communicate with
it.  (You _could_ connect it to your router using a USB connection, and
then you might want to drag the ReadySHARE printer-sharing lameware into
the picture, but why would a sane person do that?)
Message 2 of 3
All Replies
antinode
Guru
Message 2 of 3
Granddude
Thanks for the reply. I have been using the printer on USB so long I forgot it had a network port. Now I am using it as a network printer and I will promptly forget Readyshare!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 964 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
