Lucius55
May 13, 2021Follower
Recommendation for Wifi Upgrade
Greetings everyone,
Looking at upgrading from my X6 AC3200. Any opinions on the AX4300 WIFI6 , Nighthawk 6 Stream. Will this greatly improve what I currently have. Also any recommendations appreciated!
Thanks
Gary
1 Reply
Lucius55 wrote:
Greetings everyone,
Two question to start with.
Is that the R8000? X6 and AC3200 are wifi speed indicators.
Second question, why?
What's that? It isn't a Netgear model number I can find.
RAX50 or RAX45?
You might like to check the appropriate section of this place for insights into people's experiences with these:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
As to finding a replacement, only you know what you want to do and what your place looks like, so try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
and
Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
