Reply
Highlighted
Follower
Ref router placement and signal strength
I installed this Nighthawk R7000P router along with a Arris 3.0 cable modem in June/2018.  My Dell Desktop PC is connected via Ethernet cable and is located within a couple of feet to the router.  Checking signal strength today my PC is receiving DL 118.57 and UL 7.59.  Sitting within 3 ft of my router the wifi signal strength is DL 48.01 UL 19.01.  Can't figure out the extreme difference in signal strength.  Router is loccated next to an exterior wall and a EPSON PRINTER and a Laptop PC.  I purchased this router in hopes of a strong enough signal strength to be able to install a Ring Security Camera over my garage door located at the opposite end of the house.  I've added several extenders but still not enough upload to work.  Any suggestions would/will be greatly appreciated.
jht443@aol.com
Model: R7000P|Nighthawk AC2300 Smart WiFi Router with MU-MIMO
Message 1 of 2
Highlighted
NETGEAR Moderator
Re: Ref router placement and signal strength
You may want to adjust the wireless channel here is a Kb to help with the issue.
https://kb.netgear.com/25182/Resolving-poor-5GHz-wireless-range-signal-from-my-NETGEAR-router
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 319 views
  • 0 kudos
  • 2 in conversation
Announcements
