Reply
Registering Router
Treadshred
Registering Router
Bought this Nighthawk R7000 from the BX on 10 Oct and when attempting to register, it informs me that the unit, 444C7A75A0E1F, is already registered.  I suspected as much as I had to do a reset on the router when initially setting it up.  Works fine, just can't register the product nor log in from my PC's wireless.
Message 1 of 4
DarrenM
Sr. NETGEAR Moderator
Re: Registering Router
Was this unit bought new?
DarrenM
Message 2 of 4
Treadshred
Bought it in the store, but they did apply a discount.  I suspected a problem when I had to do a master reset on the router to accept the default login.  Works fine, just can't register.
Message 3 of 4
stinso
Don't expect help from Netgear. I think you should return the router since they sold you a used one. What store did you purchase it from?
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 343 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
