Reply
Remote Desktop through R6700 + GS716Tv3 Setup
Charlie-Brown
Hi All,
I recently added a GS716Tv3 ProSafe Switch to my R6700 router in order to network my new home security cameras.
Anyhow, all is good except my ability to Remote Desktop (RDP) to my desktops.  I used to be able to do so (and I still can), without any problems, so as long as I remove the ProSafe switch from my network.
When I tried to connect, I receive an error stating that the Local Security Authority cannot be reached (see attached).  I have tried adding, removing remote users, resetting the passwords, enabling and disabling UPnP, as well as disabling and re-enabling port forwarding.
Any help will be greatly appreciated.
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 4
antinode
Guru
Re: Remote Desktop through R6700 + GS716Tv3 Setup
> I recently added a GS716Tv3 ProSafe Switch [...]
   Configured how, exactly?  "added" how?  Where?  What, exactly, is
connected to what, exactly?  Hint: If a device has multiple Ethernet
ports, then "connected to device" is not enough detail.
> [...] to my R6700 router in order to network my new home security
> cameras.
   Why?  What are these cameras, and how are they connected to what?
> [...] all is good except my ability to Remote Desktop (RDP) to my
> desktops. [...]
   From where are you trying to connect to these Windows systems?  What
are all the IP addresses involved?
> [...] as well as disabling and re-enabling port forwarding.
   What are your actual port-forwarding rules?  Copy+paste is your
friend.
   You can see how the "ProSafe Switch" might have gotten its name.  You
can't get much more "Safe" than this.  No one can get past its security?
Message 2 of 4
Might also be worth throwing this at the switch community.
Switches - NETGEAR Communities
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 4
Charlie-Brown
antinode Thank You for Your Help.  Please see my answers below -
"Configured how, exactly?  "added" how?  Where?  What, exactly, is
ports, then "connected to device" is not enough detail".
[CB] Linksys modem provides Internet to R6700 router.  Router patches Internet to switch (port 1, 1000Mbps).  Desktop-1 is physically connected to router and Laptop-1 is connected to the WiFi (these computer can ping each other and have the same subnet mask and default gateway).
"Why?  What are these cameras, and how are they connected to what?"
[CB] 4 IP cameras are connected to Network Video Recorder (NVR).  NVR is connected to switch (port 15, 100Mbps, Full Duplex).  The NVR appears to be inconsequential.  I can remove it from the setup and still fail to establish a remote desktop connection.
"From where are you trying to connect to these Windows systems?  What
are all the IP addresses involved?"
[CB] Yes.  Windows 10.  Desktop-1 has a statically configured IP.  Laptop-1 has a dynamically assigned IP.
"What are your actual port-forwarding rules?"
[CB] None at the moment.  Worth noting that I forward the RDP port (3389) on the router to Desktop-1 on a as needed basis.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 638 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
