Reply
Remote access has not worked for the last couple of releases
NetGearHead5
Guide
Remote access to the router has not worked for the last couple of releases. I have it turned on in settings but using the link provided from within and without my home, it doesn't do anything.
Message 1 of 5
qwert
Re: Remote access has not worked for the last couple of releases
When you copy the link, did you include the "https://" at the beginning? and the port number at the end? something like:
https://170.211.144.29:8443
Message 2 of 5
xXxDieselxXx
Observer
Same boat here.
I can't access any port from outside my home network no matter what I do. HTTP/HTTPS.
Rebooted many times, etc.
Message 3 of 5
I just tried remote access and had no problems. It didn't work with http but it did work with https.
Message 4 of 5
xXxDieselxXx
Observer
Got my problem resolved.
It was not the R8000 router but the one Xfinity uses as modem/router (Arris XXXX)
I had the Xfinity router set as dumb modem and router functions disabled however I needed to forward the ports from there. Basically what's called "Double Router Forwarding"
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 6928 views
  • 0 kudos
  • 4 in conversation
Announcements
