Reply
Remote access not showing router
Winmoz
I have had to reset my router and now it doesn’t appear in Remote Access on iOS app. When I log on I just get a screen that prompts me to select the router I wish to manage, but the list is not populated. Also. The app refuses to acknowledge that 4G is an internet connection and only allows me to sign on if I am connected by WiFi.
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 3
vmwnek
Guide
Re: Remote access not showing router
I have the same issue with the Genie Mobile App
Please help.
Message 2 of 3
JoseAndres041
Luminary
You could try to disable/re-enable Remote Management. You can also try to remove the device as well.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 411 views
  • 0 kudos
  • 3 in conversation
Announcements
