- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Remotly access r8000 Router to re-start
- Mark as New
- Bookmark
- Subscribe
- Permalink
How can I remotly access my r8000 Router to restart it. For some reason, it is showing offline. I've tried the http://www.routerlogin.net or com browser access although after many attempts with several different browsers, I'm getting an error page. Is the page down or what? Perhaps this method only works when I'm using the same Wifi network. Not sure. Any suggestions would be most helpful. Thans!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
> Remote in the sence that I'm in another Wifi network in another State,
> far way. [...]
So, some place where a private IP address like "192.168.1.1" would be
completely useless as a pointer to your (remote) router.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "Remote
Management" and "To use remote access".
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Remotly access r8000 Router to re-start
That's a question?
To what is it connected? How remote is it?
> [...] I'm getting an error page. [...]
Swell. Are there _words_ on that "an error page"? Care to share?
> [...] Any suggestions would be most helpful. [...]
A useful problem description would reveal what you did and what
happened when you did it. As usual, showing actual actions (commands)
with their actual results (error messages, LED indicators, ...) can be
more helpful than vague descriptions or interpretations.
Note that if there's a serious communication problem with a router
like this, then communicating with it well enough to tell it to restart
may be hopeless.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Remote in the sence that I'm in another Wifi network in another State, far way. The log in attemps simply "Time Out" See the attachment below.
- Mark as New
- Bookmark
- Subscribe
- Permalink
> far way. [...]
