Reply
Replacement for bricked N900/4500 - would you recommend R7000?
d_rick
Tutor
hi,
my 4500 just died last night and i need a replacement for it. looking at what Netgear has to offer, it appears that this unit should be the logical replacement. however, it looks like many of you are having numerous issues with it and not much success in resolution from Netgear.
I plan to run the unit as an AP only and will not use ANY of the following:
-firewall/router functions
-DHCP server
-take advantage of AC band (no compatible devices, everything will be on N right now)
with that as background would you recommend the unit for purchase?
Message 1 of 8
shrek_007
Re: Replacement for bricked N900/4500 - would you recommend R7000?
Hi rick, the R7000 should a great upgrade from your 4500, with speed alone on the wireless it does definitely look good.Since it has 3 antennas, you will definitely get some longer range and connection as your AP.
Message 2 of 8
LeeH
Prodigy
Yes, recommended for your purposes. I read about someone getting it at Staples for $179.
Message 3 of 8
d_rick
Tutor
setting it up now.. 🙂
Message 4 of 8
d_rick
Tutor
Thanks for suggestion Lee!
close i just got it there for under $200 OTD which is pretty good consider taxes here in NorCal
Message 5 of 8
LeeH
Prodigy
Message 6 of 8
Retired_Member
Not applicable
You might want to check the R7000 threads and keep the receipt in a safe place.
Message 7 of 8
d_rick
Tutor
LeeH wrote:
Do you want/need the users manual?
http://www.downloads.netgear.com/files/GDC/R7000/R7000_UM_12Nov13.pdf
thanks i pulled all the sw and docs before i picked it up
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 4086 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
