Orbi WiFi 7 RBE973
Reply
Reserve IP for printer with static IP
Andy911
My printer has a static IP configured in the device itself, and it is outside the range of the router's DHCP addresses.  Is there any benefit to ALSO adding the printer's IP address to the router's IP reservation list?
Message 1 of 2
Accepted Solutions
antinode
Guru
Re: Reserve IP for printer with static IP
> [...] Is there any benefit to ALSO adding the printer's IP address to
   I don't see what that benefit might be.
   Using DCHP and reserved addresses lets you do all the management in
one place, but configuring devices with static (non-pool) addresses gets
the same effect.  In this case, if the printer will never ask for an
address from a DHCP server, and no other device will ever get that
(non-pool) address from your router's DHCP server, then I see no point
to such an address reservation.
   I'd also expect it to be harmless, except that at some future time,
someone might see that reservation, believe that it has some purpose or
effect, and expect to achieve some result by changing it.  In short,
it'd be more confusing than useful.
Message 2 of 2
All Replies
antinode
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1105 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
