Orbi WiFi 7 RBE973
Reply
Reset to factory, stops working shortly after
Twon1926
Follower
Performed a factory reset.
Only entered in new admin account password. Left everything else set to factory settings. Works, everything seems to be working. Within 10 minutes internet no longer working. Cannot access the setup page via ip, or host.
I did connect directly to modem. Computer works perfectly. When I am connected to the router I am using the enternet connection to take wifi out from being the issue.
Thoughts?
Model: R7450|Nighthawk AC2600 Smart WiFi Router
Message 1 of 2
Guru
Re: Reset to factory, stops working shortly after
What modem is it connected to?
What firmware are you on?
What are all the lights on the router doing? (color/blinking/etc)
are you able to ping the router?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 335 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
