Orbi WiFi 7 RBE973
Reply
Restrict Firewall exception to a specific incoming IP
NHStuff
I'm looking to open up Port 22 (SSH) for incoming traffic from a specific IP only (not open to the world).
Can't seem to find the proper firewall/router configuration for this.
Suggestions?
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 5
Accepted Solutions
microchip8
Master
Re: Restrict Firewall exception to a specific incoming IP
Not possible on stock firmware. Well, it's doable, but you'll need to mess with iptable rules
Message 2 of 5
All Replies
microchip8
Master
Message 2 of 5
NHStuff
Can you recommend an alternative model (or Brand) that's more suitable for this need?
I have this requirement and will be looking to replace the R7000 with something capable of handling this traffic restriction.
Thanks!
Message 3 of 5
microchip8
Master
AFAIK, no other brand supports that. Also, we can't recommend other brands here as there were people banned by doing so
Message 4 of 5
NHStuff
Yeah... that's just not ok. I see several posts from individuals needing this same functionality to keep their SIP/VOIP systems viable - past time for Netgear to step up.
Returning this to Amazon I guess.  I know I can do this in Cisco IOS, but was hoping for an easier path.
Thanks for the information.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1095 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
