Reply
FranzEckert
Follower
Restricting incoming access to a port to only some IP adresses R7000
Hi there.
I host a gameserver, but i have these unwanted incoming connections that takes a little time of the server, because it has to reject these login attempts.
I would like to make a rule that says: Incoming traffic on port 20000 is only accesible from IP adress that and IP adress that. That would take a workload of my server.
Is it possible to make this kind of restrictions?
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 2
TheEther
Guru
Re: Restricting incoming access to a port to only some IP adresses R7000
Not with stock firmware. You can set up firewall rules on your server. Your server has a much faster CPU than the router, so it should not be too costly.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 115 views
  • 0 kudos
  • 2 in conversation
Announcements
