- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Ring.com Doorbell Video Not working
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Ring.com Doorbell Video Not working
Well I am almost afrade to say it, buy I thinkj my problem with the Ring Pro is solved.
I got an email from Netgear engenieers ask me to do the following:
Thank you for responding. Regarding item 3, please access router UI. Go to Advanced TAB > Setup > WAN Setup. Set MTU Size to 1500.
mine was set to 1400.
Well , I did that and tried to active the live view from my ipad. Nothing happened. So I powered down my modem and router and then I got live view.
Went down to try the bell button and bell would not ring.
Tried to Reinstalled the bell button and in the process, it quit working and I figured I had lost power to the button. tore my hair out a little and found the fuse blown in the Ring bypass wire at the old door bell. Got another fuse, installed and instqlled the Pro button and now all is working. I have lifve view.
Stay tuned to see if it will continue to work.
Hats off to Blanca at Netgear
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I had the same problem with my old R6300v2 router. Sadly, my solution was to move over to a older Asus -N66U router. No issues with it right out the box. I get video and the push notices that I couldnt get through the R6300. Whats funny is that I'm now seeing the same problem with an Synology 1900ac router I picked up. So there has to be something in common setting wise with those two routers that might be blocking ring video and notices from coming through.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Dont know, but changing that MTU size did it for me. Netgear engeneers figured it out after going over the router debug file that I sent them.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
We had a Ring doorbell configured with our C6300 that worked perfectly. Then the Ring died and we are now on Ring replacement unit number 4. None of them worked with our router now. They upgraded us to a Ring Pro and Chime Pro. I have to give lots of credit to Ring tech support. I was on for nearly 2 hours with level 2 support and they too remoted into the router to update configuration settings, to no avail. I'm going to do a factory reset, but something is clearly screwed up on the Netgear side, because to have 4 units that don't connect is pretty bad for any manufacturere. What's up Netgear?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@Mfrank45 wrote:Well I am almost afrade to say it, buy I thinkj my problem with the Ring Pro is solved.
This tells us the Path MTU Discovery (PMTUD) does fail along the data path or is ignored by the ring.com devices. There are valid reasons why a 1500 MTU is not available, ie. on DSL PPPoE Internet connections, on VPNs, ... or a manually lowered MTU on any interface (being just for a test)
Typical cause is strictly (fully blocking) any ICMP traffic along the data path.
"Fixing" the MTU to the default resp max available is just fighting symptoms.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
""Fixing" the MTU to the default resp max available is just fighting symptoms."
i didn't understand you explanation, but it fixed my problem and that is all I cared about.
Working perfectly now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
The short answer is that the real cause is something else (likely bugs in ring.com software).
It's a bit like simply replacing tires that have uneven wear. The real problem might be worn ball joints or lack of wheel alignment. Changing the tires just hides the problem for a while.
But in this case, changing the MTU might be all you can do on your own.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Seems pretty cut and dry that its the particular Netgear Router R7000 that is the problem as its the only router that Ring has had a problem with.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
So they say. There's a circle of blame that usually applies here. Client device manufacturers blame the infrastructure (routers, switches), infrastructure manufacturers blame the network, the network provider blames the client devices,...
It's often hard to cut through to the real problem. But I agree with @schumaku's assessment - if changing the MTU to 1500 resolved the problem, something is almost certainly wrong with network software in the device.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Changing the MTU to 1500 fixed the problem for me too.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Great to finally hear that it helped someone else.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Yes, thank you for sharing this. I should have said that earlier!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Log into your router and look at connected devises. But are you looking formthe ip or mac address.?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
The mac address is listed under Device Health in the Ring app. Log into 192.168.1.1 (or wherever your router is) and match the mac address in the list of connected devices. It will probably start with A8:1B.
I have an app for my phone called Fing that keeps track of the devices connected to your network. Unlike the Netgear interface, you can add names to them, so you only have to match up names and mac addresses once.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
So it appears Liperty posted a solution regarding the aforementioned for reference. Thanks Liperty.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
as an FYI
I had a ring camera that worked fine with old wifi router
upgraded to "NETGEAR R7100LG-100EUS Nighthawk AC1900 Dual Band Wireless Wi-Fi Gigabit Cable Router with Built in 4G LTE" and it stopped working (same ssid etc)
when re-setting up the ring, it would not see the network. In the end I set the 2g network "mode" to "up to 54 Mbps". Now it can see the network and register properly. everything works without any other settings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Don't know if this is related, (I've found that "MTU" is almost never the answer that works) but I have various network hardware, and run a commercial grade firewall. I use Netgear routers in access point mode. I found that that the port listing on the Ring support page is incorrect. The Ring doorbell accesses a lot of UDP ports outside the range specified by their tech support.
I found that opening the following ports works for the Ring Doorbell:
TCP 80, 443
UDP 16500-65535
TCP/UDP 15063
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Maybe the MTU " amost never" has an effect, but in my case it did. If you read the thread, I had the problem for months and no one at ring or netger could come up with an answer. I was on the phone for hours at a time. I think they tried changing the ports without any positive results. My ring has worked perfectly ever since the little lady at Netgear made the MTU suggestion.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi, I had similiar issues using varying router models. I overcame the problem by:
1. Disabling Wireless Security (Open); and
2. Enabling Access Control - only devices with a specified MAC address may join my network (Security from Network Intruders).
Network speeds and the Ring Pro video reliability increased.
Cheers, Leon Torossian.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
When i tried to change the mtu to 1500
After saving, it just goes back to 1458
How can I change to 1500?
Many thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
HI
I have 3 ring products
Doorbell (1st gen)
Stickup Cam
Flood light
The Doorbell and stickup cam work fine, since November 2017 my floodlight started having issues with blank video and connectivity info.
I did a reset on the floodlight and it would no longer connect to wifi.
I've now found out the issue was with a firmware update in November 2017, I today upgraded to a beta firmware (from https://kb.netgear.com/000053870/R7000-Firmware-Version-1-0-9-26-Hot-Fix) and now I have no issues with my ring products.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I ordered a Ring video doorbell from ADT to add to my ADT pulse system and the technician couldn't get it to take my wifi
password to connect. He advised me to talk to my isp people so i called Rise Broadband and they say talk to the router people.
Router is a R7300DST/Nighthawk. Instead i just got my refund back on the Ring smart doorbell. The wife says she would
just rather have a camera on the front porch anyway. Just for kicks i just checked to see if there were any blogs about Ring not working
with Netgear routers. Boy was i surprised. I'm glad i made my decision.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
The first versions doesnt support 5GHz wifi and only 2.4GHz.
I believe your router should have 2.4 capability.
Meanwhile ring pro camera supports 5GHz and I have the same router as you have and all working fine
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Its late in the game. If you follow all the post, Netgear did come up with a solution and I had it working. Since then Inhave gotten Google Fiber and the Ring Pro connected and works perfectly.
User | Count |
18 | |
13 | |
6 | |
4 | |
4 |
