Orbi WiFi 7 RBE973
Reply
Rounter Login taking me to home screen
TigerKatLily
Follower
Quick back story, bought this router because the old service provider we had (Mediacom) their routers were horrible. Moved to a new state and now we have Spectrum.
I USED to be able to log into my router admin page and do normal basic stuff like update the router name and password, or see what devices were connected. Now I can't do that.
I have tried several times to log into the routerlogin.com or .net and every time it brings me back to Netgear's main website.
Tried to log in with my Nighthawk app, and it won't conncect to the WiFi.
What am I doing wrong here?
Model: C6250|AC1600 WiFi Cable Modem Router
Message 1 of 3
Guru
Re: Rounter Login taking me to home screen
Netgear has set up a community forum specifically for the Cable Modem products. Most of the people who watch that forum are more likely to have experience with Cable modems and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Try clearning all browser caches.
Try a different browser.
Try 192.168.0.1 or 192.168.100.1
Thank you.
Message 2 of 3
Guru
try using its ip address.
the default is 192.168.1.1
unless you changed it.
You can also try the modem's side which is 192.168.100.1
You have the C6250?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 604 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
