Reply
Router Dropping Internet Connection
Philbomb
My router drops it's signal multiple times daily.  I downloaded an update about two weeks ago.  Prior to the update. this was not happening.   What do I do to regain a consistant signal?
Model: R6700v2|Nighthawk AC1750 Smart WiFi Router
Message 1 of 5
Accepted Solutions
Blanca_O
NETGEAR Moderator
Re: Router Dropping Internet Connection
Hi Philbomb,
Have you tried changing the channel on the router?
You may want to try to play around with the channels to see which channel is best to use.
Here's a reference of how to change wireless channel:
https://kb.netgear.com/23783/
Blanca
Community Team
Message 4 of 5
All Replies
JamesGL
Master
Hi Philbomb,
Does it happen on both wired and wireless devices?
Have you reset the router to factory default?
Message 2 of 5
Philbomb
It happens on wireless connections. Yes, I reset the router to factory specs.
Message 3 of 5
Blanca_O
NETGEAR Moderator
Hi Philbomb,
Blanca
Community Team
Message 4 of 5
Blanca_O
NETGEAR Moderator
Hi Philbomb,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 954 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
