Orbi WiFi 7 RBE973
Reply
Router Not Working ?
Cbouvier
Follower
Hi,,,,,,,,,,,I am not getting wifi off my router.
  I have turned off and on a number of times to no avail.
My pc is hooked directly to the Netgear box and works fine.
The lights on on my router are the following:
First 2 are on and bright white, which I believe are the power and something else.
The next 4 are off which are 2.5 gh  5ghz and 1 and 2 pictures of connections.
Then the numbers 1-4   1 is on and white,  2 is on and orange,  3 is off   and 4 is orange.
The last 2 are off.
When I looked at Netgear Genie and it says the Wireless is not connected.
I am obviously not router savvy but if you can help me, it would be greatly appreciated.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 2
Accepted Solutions
antinode
Guru
Re: Router Not Working ?
> [...] The next 4 are off which are 2.5 gh  5ghz and 1 and 2 pictures
> of [USB] connections.
   Apparently, the wireless network radios are switched off.
> The last 2 are off.
   Does that include the "WiFi On/Off button with LED" that's described
in the User Manual?
   Visit http://www.netgear.com/support , put in your model number, and
look for Documentation.  Get the User Manual.  Read.
Message 2 of 2
All Replies
antinode
Guru
> The last 2 are off.
in the User Manual?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2971 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
