Reply
Router R7000P Randomly Rebooting
dacsilva
for the past few days this router is randomly rebooting or turning off, about 1 year old, is that the expected life of one of these units?
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 5
microchip8
Master
Re: Router R7000P Randomly Rebooting
A couple of issues could be a cause
- overheating
- faulty power supply
- bad configuration. might need a factory reset and configure from scratch
Routers should last at least several years, if not longer
Routing: NETGEAR R7800 - Voxel Firmware 1.0.2.88SF & Kamoj addon
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 16 TB
Message 2 of 5
yyz2phz1991
My R7000P router functioned perfectly until the f/w was updated to V1.3.1.64 (latest f/w as of 5/6/2019 per Netgear website) then it would not reboot successsfully.
Got pissed with it and replaced it with another brand that has been rock-solid through firmware updates.
Decided to troubleshoot R7000P by letting it reboot for several hours.
It finally settled down and rebooted successfully to where I could connect to it via ethernet and downgrade the firmware to V1.3.0.8.
I chose this version arbitrarily.
This f/w version has allowed the R7000P to reboot and settle down within 2-3 minutes.
I have used the R7000P for several hours, then turned it off.
Then I turned it on, and it rebooted within 3 minutes as normal.
SO, NETGEAR, PLEASE FIX F/W V 1.3.1.64
Hope this helps you frustrated NetGear heads!
Message 3 of 5
dacsilva
it is sad how poorly this 1 year old router works. I will be replacing it with a Ubiquiti, more expensive, but the remote work requirements i think it is necessary.
Message 4 of 5
yyz2phz1991
Important update July 27,2020.
I decided to have another go at troubleshooting why this R7000P would not reboot successfully.
It turns out that the R7000P requires a power source rated for 12V 3.5A, and the supplied power adapter was 12V 1.0A.
I purchased a NetGear 12V 3.5A power adapter on eBay.
The R7000P now boots up in under 3 minutes.
With the 12V1.0A power adapter it would sit there and reboot for a few hours before booting up.
Hope this helps.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 724 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
