Orbi WiFi 7 RBE973
Reply
Router R8500 and PowerLINE 1200's IP address.
16Paws
Tutor
I have a PowerLINE 1200 connected to a R8500 router. Every time the router reboots, the IP addresses to the connected devices get changed. Can I force one of the connected devices to be assigned the same IP address each time the router is rebooted? If yes, how?
Message 1 of 4
Accepted Solutions
Guru
Re: Router R8500 and PowerLINE 1200's IP address.
You can usually set an IP address reservation. It should be under advanced---setup---lan setup    From here you should be able to reserve addressess for specific devices. Page 72 of the manual i think.
https://www.netgear.com/support/product/R8500.aspx
Message 2 of 4
All Replies
Guru
Message 2 of 4
16Paws
Tutor
Thank you very much! I wasn't sure if I was asking the question correctly to find out what I needed to know. I can read the manual to find out the additional information to make sure everything works properly. Thanks for the reference to it. I very much appreciate the help.
Message 3 of 4
Guru
Hope it works out well for you!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1064 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
