Reply
Router dropping connection
benji007420
Our internet keeps connecting then disconnecting in about 30 second intervals. Tech moved it to a different channel yesterday, today it moved back and I can't get it to change???
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 3
Re: Router dropping connection
Is that wifi?
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 3
William10a
Master
Are you talking about the 2.4 ghz or the 5ghz band or both if it the wifi dropping?
Do you have a hardwired lan to computer to see you the connection via the lan ports as well?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 488 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
