Reply
Router firm Ware recovery model R6900P
hectorq1
Follower
Hello
I am using Windows 10, I was updating the firmware on  my router a R6900P Night Hawk AC1900. when a 2nd party reset and turn off the router. More then likly the Bios or firmware was corrupted.
The question is how do I corrected, replace it or upload a new version?
what is the best version for this modem?
Thank you for any advice or suggestions.
Message 1 of 2
Guru
Re: Router firm Ware recovery model R6900P
I'd highly recommend any firmware updates be done over a hardwired connection.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Current setup: CAX80->Trendnet TEG-S380->GS716T-> RBK752->pi-hole
1.4gig download/50mbps upload
We’re members of the public helping out on our own time.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 189 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
