Orbi WiFi 7 RBE973
Reply
Router login troubles R7000
Beekmans-online
I bought a second-hand Netgear R7000. When I tried to connect to this router via routerlogin.net it shows a site with the text "Detecting if there is an existing router in your network, please wait". It keeps detecting on and on. It won't continue.
I have tried a reset to factory settings but it didn't help.
I have tried a firmware update by TFTP and it says "No responce from server"
Can anyone please help me?
Thanks
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 7
Accepted Solutions
Beekmans-online
Re: Router login troubles R7000 [SOLVED]
My problem occur when I try to login via a Mac (mac OS Sierra).
I tried a Windows PC and had no trouble logging in.
Once I changed the IP-address, from the router, to a static one I could logging from my Mac too!!!
So, every one thank you very much for thinking.
Message 7 of 7
All Replies
IrvSp
Master
Open browser and enter 192.168.1.1 into the URL location and if you get a prompt for a userID and password use admin and password, that should get you in. If not, try 192.168.0.1 and see if that works.
Doesn't, open a CMD prompt and enter IPCONFIG /ALL and look at the Gateway IP Address. If it isn't one on the above, try that.
Message 2 of 7
Beekmans-online
I did those things already. I keep getting this annoying message. It seems like the router can't take this hurdle.
My router has IP 192.168.1.1 and I have 192.168.1.2
Message 3 of 7
VE6CGX
Master
The router may not be in router mode. Reset it before trying to do anything.
Message 4 of 7
As you say you already did the reset, maybe you have just discovered the delights of second-hand kit.
Do you know that it worked when you bought it?
Message 5 of 7
IrvSp
Master
What is the GATEWAY IP Address?
Message 6 of 7
Beekmans-online
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 9203 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
