Reply
Router looses internet on wifi and ethernet, it has to be restarted every other day.
Oats467
Follower
My Netgear R7000 AC1900 looses internet,  wifi and ethernet has no internet.  This hapens every couple of days,  the only fix is to restart it.  I have the most recent firmware and I just did a factory restart, I also have two of these and they both do the same thing.  I also just upgraded my cable modem to a netgear cm500v, no change.
If it is a firmware problem what one should I use?
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 2
antinode
Guru
Re: Router looses internet on wifi and ethernet, it has to be restarted every other day.
> [...] I have the most recent firmware [...]
   As always, an actual version number would be more useful than your
opinion of what's "the most recent" today.
   You may not know if it's a firmware problem until you try different
firmware.  The third-from-most-recent seems to satisfy more people than
"the most recent".
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 227 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
