- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Router needs to be updated?
- Mark as New
- Bookmark
- Subscribe
- Permalink
My router died two days ago after 4 months of ownership and no issues. I called tech support and they informed me the router needed to be updated and they could help if I paid them $150 for a one year service plan. Is it true routers will just stop working if they aren't updated? Can this happen after 4 months? I refused to pay the money since I felt I was being scammed, so now I have a $300 door stop and I'll go back to renting one from Xfinity.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Router needs to be updated?
Not sure who you called but the C7100V is a modem/router combo device. An update doesn't get pushed by netgear or the end user. It has to come from the isp. Makes me suspisious of whoever you called. There's many scam/con sites if you google for a support number.
what issues are you actually having? details help and we're here to help and free.
What are the led's doing?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I called Netgear support. The lights are just cycling repeatedly. All on, 2.5mgz/5gz blink twice, power button on, all on, etc, etc.
- Mark as New
- Bookmark
- Subscribe
- Permalink
try this.
while powered on, disconnect the coax cable from the modem.
Then push and hold reset for up to 30 seconds while its powered on.
Then let it reboot. Leave the coax disconnected.
Does it boot up properly?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No luck. The light cycling continues no matter what I do.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If its only 4 months old, you can start the rma process.
Click on "mynetgear" at the top. register an account and then the device.
From there, you can start the rma process.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Rma? Is that different than calling support? Lol.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Most routers have a 1 (or 2 in some areas) year warranty if purchased new. If you're still within the warranty period, you should be able to exchange it through the rma process.
RMA=return merchandise authorization.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
