Reply
Highlighted
Follower
Router not connecting
The last couple of days my internet has been spotty. All of my devices disconnected and when reconnected recieved a message saying password was incorrect..it wasn't. When I turned the power off (waited) then turned it back on, the 1-4 LEDs lit up red (amber?), and have stayed lit. The Wi-fi ON/off button with LED is lit, and the power and internet LEDs are barely lit amber. NO ethernet cables are plugged in. I've tried restarting and nothing...help, please?
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 2
Highlighted
Re: Router not connecting
 Greetings,
The behavior you are describing can have more that one cause.
-Bad or failing power supply
-Corrupt firmware
-Damaged hardware (router itself)
Some things that might help us:
What FW revision was the router running?
Do you know what preceeded this behavior?
Router was working when I went to sleep, when I woke up it was not functioning?
Failed firmware upgrade
Router was subjected to power surge / dip, etc?
Where to start:
TFTP FW Recovery
FW For R7000P - 1.3.1.64
Start with this.  If you find/discover other information you feel is relavant to your issue, please reply and update with this information.
~Comcast 1 Gbps/50 Mbps SB8200 > R8000P
~R8000P FW:1.4.1.62 ~R7000 FW:1.0.9.42
~R6400 FW:1.0.1.52 ~Orbi-AC3000 FW:2.5.1.8
~EX3700 FW:1.0.0.84
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 257 views
  • 0 kudos
  • 2 in conversation
Announcements
