Reply
Highlighted
Router not restarting after I did a firmware update and the amber light is just on.
Hello, I had this router for 3 years and when I tried to update a firmware it was trying to boot up but it never booted up. Also this happend over the weekend where I was not home and I was gone but sunday night it tried to connect to the internet but it kept rejecting the password even tho i know i typed the password in correctly. I dont really know how to solve this I would appreciate someone helping me with this.
Model: AC2400|Nighthawk AC2400 Smart WiFi Router
Message 1 of 4
Highlighted
Guru
Re: Router not restarting after I did a firmware update and the amber light is just on.
If the only light on is the power light and its amber, it tends to indicate a problem with the firmware. If you're unable to get back into the router, then you might be a canidate for a tftp recovery.
 are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
CAX80-> RBK53-> GS716v2-> TP-Link M9Plus
Message 2 of 4
Highlighted
sadly that didnt work unless there is another way to do it.
Message 3 of 4
Highlighted
Guru
Which way? tftp? nmrpflash?
Where did it fail? There's lots of steps that can fail which is why i included a video walk through.
Details help more than a short "it didn't work"
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 145 views
  • 0 kudos
  • 2 in conversation
Announcements
